sharkbits [2023/01/03 17:58] ariel |
sharkbits [2024/08/05 15:15] (current) |
| Line 1: | Line 1: | ||
| - | ^SKU / Image ^Name ^Flutes ^Shank Diameter ^Cut Diameter ^Cutting Height ^Feed Rate ^Plunge Rate ^Cut Depth ^Degree ^Tip ^Overall Length ^Coating ^Best used for ^ | + | ===== Download this convenient chart to have it on hand ===== |
| - | |[[https:// | + | [[https:// |
| - | |[[https:// | + | |
| - | |[[https:// | + | ^SKU / Image ^Name ^Flutes ^Shank Diameter ^Cut Diameter ^Cutting Height ^Feed Rate ^Plunge Rate ^Cut Depth ^Degree ^Tip ^Overall Length ^Coating ^Best used for ^ |
| - | |[[https:// | + | |[[https:// |
| - | === *Please note that default settings are to be adjusted according to what material, speeds/feedsthat | + | |[[https:// |
| - | Download this convenient chart to have it on hand {{ : | + | |[[https:// |
| + | |[[https:// | ||
| + | === *Please note that default settings are to be adjusted according to what material, speeds/feeds that you are using. Use theses libraries as a starting point for your projects. Use at your own risk. === | ||
