docs:software:overview [2024/11/19 20:13] admin created |
docs:software:overview [2025/05/08 13:58] (current) admin |
| Line 1: | Line 1: | ||
| - | ==== CNC Software Overview | + | ==== CNC Software Overview ==== |
| A typical CNC workflow consists of three steps: | A typical CNC workflow consists of three steps: | ||
| - | ^ **CAD** | + | ^ **CAD** |
| - | | Create Drawing | + | | Create Drawing |
| - | Within each of these, you have a lot of freedom to choose which applications you want to make use of in your own preferred workflow. You can select the ones you are most comfortable, | + | Within each of these, you have a lot of freedom to choose which applications you want to make use of in your own preferred workflow. You can select the ones you are most comfortable, |
| - | For example, if your work is oriented toward signage and artwork, you'd prefer | + | |
| - | ==== 1. CAD ==== | ||
| - | CAD consists of applications you can use to create or modify 2D Drawings or 3D m | ||
| - | > TIP: Some CAM application also include CAD functionality, | ||
| - | Examples include: | ||
| - | * [[https:// | ||
| - | * Adobe Illustrator (2D) | ||
| - | * and many more | ||
| - | In most cases you export your drawings as CAM compatible files, for example | ||
| - | * DXF (2D) | ||
| - | * SVG (2D) | ||
| - | * STL (3D) | ||
| - | For more details, refer to [[docs: | ||
| - | ==== 2. CAM ==== | ||
| - | CAM software converts CAD drawings/ | ||
| - | * [[http:// | ||
| - | ==== 3. CONTROL ==== | ||
| - | CONTROL software is tasked with streaming GCODE to your machine controller. It a lso handles all the other aspects of Machine interfacing, | ||
| - | For example, OpenBuilds® CONTROL:\\ | ||
| - | root@server1:/ | ||
| - | ==== CNC Software Overview ===== | ||
| - | A typical CNC workflow consists of three steps: | ||
| - | ^ **CAD** | ||
| - | | Create Drawing | ||
| - | Within each of these, you have a lot of freedom to choose which applications you want to make use of in your own preferred workflow. You can select the ones you are most comfortable, | ||
| - | For example, if your work is oriented toward signage and artwork, you'd prefer Vectric over Fusion360, because Fusion shines for engineering users who want to machine engineering type parts. If you run a Laser, you'd prefer Lightburn over the others as it focusses on Laser only. | ||
| ==== 1. CAD ==== | ==== 1. CAD ==== | ||
| Line 81: | Line 17: | ||
| Examples include: | Examples include: | ||
| * [[https:// | * [[https:// | ||
| - | * [[https:// | + | * [[https:// |
| Line 91: | Line 28: | ||
| In most cases you export your drawings as CAM compatible files, for example | In most cases you export your drawings as CAM compatible files, for example | ||
| * DXF (2D) | * DXF (2D) | ||
| * SVG (2D) | * SVG (2D) | ||
| * STL (3D) | * STL (3D) | ||
| - | For more details, refer to [[docs: | + | For more details, refer to [[:docs: |
| ==== 2. CAM ==== | ==== 2. CAM ==== | ||
| Line 103: | Line 42: | ||
| - | * [[https:// | + | * {{: |
| + | * [[https:// | ||
| * [[http:// | * [[http:// | ||
| ==== 3. CONTROL ==== | ==== 3. CONTROL ==== | ||
| Line 121: | Line 62: | ||
| - | For example, OpenBuilds® CONTROL:\\ | + | For example, OpenBuilds® CONTROL: |
