docs:software:overview
Differences
Link to this comparison view
Both sides previous revision Previous revision
Next revision
Previous revision
docs:software:overview [2024/09/09 18:43]
admin
docs:software:overview [2025/05/08 13:58] (current)
admin
Line 1: Line 1:
-==== CNC Software Overview =====+==== CNC Software Overview ====
 A typical CNC workflow consists of three steps: A typical CNC workflow consists of three steps:
-^  **CAD**  ^ ^  **CAM**  ^ ^  **CONTROL**  ^+^  **CAD**    ^ ^  **CAM**    ^ ^  **CONTROL**    |
 |  Create Drawing  |  {{fa>arrow-right|}}  |  Convert to GCODE  |  {{fa>arrow-right|}}  |  Send to controller  | |  Create Drawing  |  {{fa>arrow-right|}}  |  Convert to GCODE  |  {{fa>arrow-right|}}  |  Send to controller  |
-Within each of these, you have a lot of freedom to choose which applications you want to make use of in your own preferred workflow. You can select the ones you are most comfortable, or fit your sort of work better: +Within each of these, you have a lot of freedom to choose which applications you want to make use of in your own preferred workflow. You can select the ones you are most comfortable, or fit your sort of work better: For example, if your work is oriented toward signage and artwork, you'd prefer Vectric over Fusion360, because Fusion shines for engineering users who want to machine engineering type parts. If you run a Laser, you'd prefer Lightburn over the others as it focusses on Laser only.
-For example, if your work is oriented toward signage and artwork, you'd prefer Vectric over Fusion360, because Fusion shines for engineering users who want to machine engineering type parts. If you run a Laser, you'd prefer Lightburn over the others as it focusses on Laser only. +
 ==== 1. CAD ==== ==== 1. CAD ====
-CAD consists of applications you can use to create or modify 2D Drawings or 3D models, to use as input files for your CAM application: +CAD consists of applications you can use to create or modify 2D Drawings or 3D models, to use as input files for your CAM application:
-> TIP: Some CAM application also include CAD functionality, so you may see some applications listed and both sections.  +> TIP: Some CAM application also include CAD functionality, so you may see some applications listed and both sections.
 Examples include: Examples include:
-  * [[https://www.autodesk.com/campaigns/fusion-360-for-hobbyists|Fusion 360]] (Recommended) (2D and 3D)+
 +  * [[https://www.autodesk.com/campaigns/fusion-360-for-hobbyists|Fusion 360]] ( Recommended) (2D and 3D)
   * [[https://help.sketchup.com/en/downloading-older-versions|Sketchup MAKE 2017 Free]] (Recommended) (2D and 3D)   * [[https://help.sketchup.com/en/downloading-older-versions|Sketchup MAKE 2017 Free]] (Recommended) (2D and 3D)
-  * [[https://openbuildspartstore.com/vectric/|Vectric Aspire/Cut2D/VCarve]] (Recommended) (2D and 3D)+  * [[https://openbuildspartstore.com/vectric/|Vectric Aspire/Cut2D/VCarve]] (Re commended) (2D and 3D)
   * [[https://www.qcad.org/en/|QCAD]] / [[https://librecad.org/|LibreCAD]] (2D)   * [[https://www.qcad.org/en/|QCAD]] / [[https://librecad.org/|LibreCAD]] (2D)
   * [[https://inkscape.org/|Inkscape]] (2D)   * [[https://inkscape.org/|Inkscape]] (2D)
Line 27: Line 28:
 In most cases you export your drawings as CAM compatible files, for example In most cases you export your drawings as CAM compatible files, for example
   * DXF (2D)   * DXF (2D)
   * SVG (2D)   * SVG (2D)
   * STL (3D)   * STL (3D)
-For more details, refer to [[docs:software:file-errors|Troubleshooting CAD files]] for help with file formats, and cleaning up files to make them ready for CAM.+For more details, refer to [[:docs:software:file-errors|Troubleshooting CAD files ]] for help with file formats, and cleaning up files to make them ready for CAM.
 ==== 2. CAM ==== ==== 2. CAM ====
Line 39: Line 42:
-  * {{::openbuilds-icon.png?16|OpenBuilds CAM}} [[https://cam.openbuilds.com|OpenBuilds® CAM]] (Recommended)  (2D CAM) +
-  * {{::icon-vcarve.png?16|Vectric}} [[https://openbuildspartstore.com/vectric/|Vectric Aspire/Cut2D/VCarve]] (Recommended)  (2D and 3D) +  * {{:openbuilds-icon.png?16|OpenBuilds CAM}}[[https://cam.openbuilds.com|OpenBuilds® CAM]] (Recommended) (2D CAM)
-  * {{::fusion-icon.png?16|Fusion 360}} [[https://www.autodesk.com/campaigns/fusion-360-for-hobbyists|Fusion 360]] (Recommended)  (2D and 3D CAM) +  * {{:icon-vcarve.png?16|Vectric}}[[https://openbuildspartstore.com/vectric/|Vectric Aspire/Cut2D/VCarve]] (Recommended) (2D and 3D)
-  * {{::icon-lightburn.png?16|Lightburn}} [[https://openbuildspartstore.com/lightburn/|LightBurn]] (Laser specific CAM) +  * {{:fusion-icon.png?16|Fusion 360}}[[https://www.autodesk.com/campaigns/fus        ion-360-for-hobbyists|Fusion 360]] (Recommended) (2D and 3D CAM)
-  * {{:icon-rhinocam.png?16|RhinoCAM and VisualCAM}}[[https://mecsoft.com/|RhinoCAM and VisualCAM]] +  * {{:icon-lightburn.png?16|Lightburn}}[[https://openbuildspartstore.com/ligh        tburn/|LightBurn]] (Laser specific CAM)
-  * [[https://openbuilds.com/projectresources/sketchucam.1/|SketchuCAM]] for SketchUp (2D CAM)+  * {{:icon-rhinocam.png?16|RhinoCAM and VisualCAM}}[[https://mecsoft.com/|Rhino CAM and VisualCAM]]
 +  * [[https://openbuilds.com/projectresources/sketchucam.1/|SketchuCAM]] for Ske tchUp (2D CAM)
   * [[https://sameer.github.io/svg2gcode/|svg2gcode]] Perfect for Pen Plotters   * [[https://sameer.github.io/svg2gcode/|svg2gcode]] Perfect for Pen Plotters
   * [[https://grid.space/kiri/|Kiri:moto]] (3D CAM)   * [[https://grid.space/kiri/|Kiri:moto]] (3D CAM)
   * [[http://flatcam.org/|FlatCAM]] (PCB Milling)   * [[http://flatcam.org/|FlatCAM]] (PCB Milling)
-For more details, refer to [[docs:software:cam|CAM Applications]] for help configuring your CAM application with the correct Post Processor, etc+For more details, refer to [[:docs:software:cam|CAM Applications]] for help configuring your CAM application with the correct Post Processor, etc
 ==== 3. CONTROL ==== ==== 3. CONTROL ====
Line 57: Line 62:
-  * {{::openbuilds-icon.png?16|OpenBuilds CAM}} [[https://software.openbuilds.com|OpenBuilds® CONTROL]] (Recommended) - Focused on keeping the learning curve to the minimum, helps you get started with the minimum of prior knowledge, yet still really powerful and feature packed with support for Probing, Macros, Machine Profiles, a 3D Gcode Viewer, Mobile Jog Widget, Surfacing Wizard and many more features.  For more information refer to [[docs:software:openbuilds-control|OpenBuilds CONTROL - Introduction]]
-  * [[https://winder.github.io/ugs_website/guide/platform/|Universal GCODE Sender Platform 2]] - Suitable for slower computers
-For example, OpenBuilds® CONTROL:\\ +  * {{:openbuilds-icon.png?16|OpenBuilds CAM}} [[https://software.openbuilds.com|OpenBuilds® CONTROL]] (Recommended) - Focused on keeping the learning curve to the minimum, helps you get started with the minimum of prior knowledge, yet still really powerful and feature packed with support for Probing, Macros, Machine Profiles, a 3D GCODE Viewer, Mobile Jog Widget, Surfacing Wizard and many more features. For more information refer to [[:docs:software:openbuilds-control|OpenBuilds CONTROL - Introduction]]
-{{:docs:software:openbuilds-control.png?400|}}+  * [[https://winder.github.io/ugs_website/guide/platform/|Universal GCODE Sender Platform 2]] - Suitable for slower computers
 +For example, OpenBuilds® CONTROL:
 +{{:docs:software:openbuilds-control.png?400}}
docs/software/overview.1725907416.txt.gz · Last modified: 2024/09/09 18:43 by admin
