docs:interface:prepare-blackbox-v2.3-2.6 [2025/01/16 20:00] admin |
docs:interface:prepare-blackbox-v2.3-2.6 [2025/01/16 20:04] (current) admin |
| Line 1: | Line 1: | ||
| ==== Prepare a BlackBox V2.3, V2.4, V2.5, V2.6 or V2.7 to work with OpenBuilds Interface ==== | ==== Prepare a BlackBox V2.3, V2.4, V2.5, V2.6 or V2.7 to work with OpenBuilds Interface ==== | ||
| - | The following steps are required for OpenBuilds Interface to connect to an OpenBuilds BlackBox v2.3- V2.6. | + | The following steps are required for OpenBuilds Interface to connect to an OpenBuilds BlackBox v2.3 - V2.7 |
| - | > At the time BlackBox versions V2.3 - V2.6 were current, Interface had not been invented yet. Luckily, there is a way to retrofit these older BlackBoxes, avoiding the need to replace them with a newer BlackBox to work with Interface! You will have to do a very easy modification to the PCB. | + | > At the time BlackBox versions V2.3 - V2.7 were current, Interface had not been invented yet. Luckily, there is a way to retrofit these older BlackBoxes, avoiding the need to replace them with a newer BlackBox to work with Interface! You will have to do a very easy modification to the PCB. |
