docs:interface:prepare-blackbox-v2.3-2.6 [2022/12/28 19:37] admin |
docs:interface:prepare-blackbox-v2.3-2.6 [2025/01/16 20:04] (current) admin |
| Line 1: | Line 1: | ||
| - | ==== Prepare a BlackBox V2.3, V2.4, V2.5 or V2.6 to work with OpenBuilds Interface ==== | + | ==== Prepare a BlackBox V2.3, V2.4, V2.5, V2.6 or V2.7 to work with OpenBuilds Interface ==== |
| - | The following steps are required for OpenBuilds Interface to connect to an OpenBuilds BlackBox v2.3- V2.6. | + | The following steps are required for OpenBuilds Interface to connect to an OpenBuilds BlackBox v2.3 - V2.7 |
| - | > At the time BlackBox versions V2.3 - V2.6 were current, Interface | + | > At the time BlackBox versions V2.3 - V2.7 were current, Interface |
| Line 30: | Line 30: | ||
| This modification allows Interface to communicate with the BlackBox V2.4, V2.5 and V.26 boards via AUX1. It does change one behavior of the BlackBox - it is no longer powered over USB - so the 24v power will need to be connected and turned on whenever you want to work with the BlackBox. As you need 24v connected and switched on for the stepper motors and other accessories as well, it will not be a noticeable difference to most users. | This modification allows Interface to communicate with the BlackBox V2.4, V2.5 and V.26 boards via AUX1. It does change one behavior of the BlackBox - it is no longer powered over USB - so the 24v power will need to be connected and turned on whenever you want to work with the BlackBox. As you need 24v connected and switched on for the stepper motors and other accessories as well, it will not be a noticeable difference to most users. | ||
| - | === c) Insert the TVS Module onto the ICSP header === | + | === c) Replace the Top Panel === |
| - | Included with your Interface, you will find a "TVS Module" | + | |
| - | The BlackBox has a 6 pin header labelled ICSP. It is important that you install this module onto the ICSP header. | + | |
| - | Line up the " | + | |
| - | [[https:// | + | |
| - | === d) Replace the Top Panel === | + | |
| Make sure the Fan is plugged in - then place the top panel with fan back onto the BlackBox and reattach using the 4 screws you removed in step (a) above | Make sure the Fan is plugged in - then place the top panel with fan back onto the BlackBox and reattach using the 4 screws you removed in step (a) above | ||
