docs:interface:firmware-update-control [2024/04/23 19:09] admin |
docs:interface:firmware-update-control [2024/08/05 15:15] (current) |
| Line 4: | Line 4: | ||
| Make sure to download and install the latest version of OpenBuilds CONTROL. | Make sure to download and install the latest version of OpenBuilds CONTROL. | ||
| - | [[https:// | + | [[https:// |
| Note, only available in the {{fa> | Note, only available in the {{fa> | ||
| Line 15: | Line 15: | ||
| > **NB** The cable included with your Interface, is a Power cable, not a Data cable, please use your own USB-C Cable! | > **NB** The cable included with your Interface, is a Power cable, not a Data cable, please use your own USB-C Cable! | ||
| - | > TIP: If you require the FTDI Device Drivers, see https:// | + | > TIP: If you require the Device Drivers, see https:// |
| === 3.1.1.2 Put your Interface into Bootloader Mode === | === 3.1.1.2 Put your Interface into Bootloader Mode === | ||
| - | We will use the two buttons on the left-side of the Interface, to put the Interface into " | + | We will use the two buttons on the side of the Interface, to put the Interface into " |
| - | * Hold down the **MODE** button on the left side and keep holding it down (This will tell the controller to be in FLASH mode when it resets) | + | * Hold down the **MODE** button on the side and keep holding it down (This will tell the controller to be in FLASH mode when it resets) |
| - | * Click the **RESET** button on the left side of the Interface (This resets the controller, so it can boot up into Bootloader mode - it will check MODE is being held down to know whether to go into Bootloader Mode) | + | * Click the **RESET** button on the side of the Interface (This resets the controller, so it can boot up into Bootloader mode - it will check MODE is being held down to know whether to go into Bootloader Mode) |
| * Let go of the **MODE** button | * Let go of the **MODE** button | ||
| Your interface should now show just a black screen. | Your interface should now show just a black screen. | ||
| === 3.1.1.3 Launch the Firmware Update tool === | === 3.1.1.3 Launch the Firmware Update tool === | ||
| Line 32: | Line 33: | ||
| Start OpenBuilds CONTROL and go to Wizards and Tools > Firmware Flashing tool | Start OpenBuilds CONTROL and go to Wizards and Tools > Firmware Flashing tool | ||
| === 3.1.1.4 Flash the latest Firmware === | === 3.1.1.4 Flash the latest Firmware === | ||
| - | * Under the Controller Type, select OpenBuilds Interface | + | * Click the INTERFACE tab |
| * Under Port, select USB Serial port that belongs to the OpenBuilds Interface | * Under Port, select USB Serial port that belongs to the OpenBuilds Interface | ||
| * Click Flash button in the Wizard | * Click Flash button in the Wizard | ||
| Line 43: | Line 44: | ||
| * Click Reset once the flashing is completed | * Click Reset once the flashing is completed | ||
| === 3.1.1.5 Log === | === 3.1.1.5 Log === | ||
| Line 49: | Line 50: | ||
| The Serial console log will let you know whether the flashing was successful. Click **Reset** once the flashing is completed to restart the Interface with the new firmware | The Serial console log will let you know whether the flashing was successful. Click **Reset** once the flashing is completed to restart the Interface with the new firmware | ||
| === 3.1.1.6 Extra: Alternative to MODE/RESET Buttons === | === 3.1.1.6 Extra: Alternative to MODE/RESET Buttons === | ||
| Line 57: | Line 58: | ||
