docs:interface:firmware-update [2024/04/23 19:07] admin |
docs:interface:firmware-update [2024/08/05 15:15] (current) |
| Line 5: | Line 5: | ||
| Your OpenBuilds Interface ships with Firmware preinstalled from the factory, but as Interface is a cutting edge control system, we are continuously updating the firmware, improving it and adding new features. | Your OpenBuilds Interface ships with Firmware preinstalled from the factory, but as Interface is a cutting edge control system, we are continuously updating the firmware, improving it and adding new features. | ||
| - | To make it as easy as possible for you to update the Interface' | + | Firmware Changelog: See https:// |
| - | > {{fa> | + | |
| Line 14: | Line 12: | ||
| * Method 1: [[{}docs: | * Method 1: [[{}docs: | ||
| - | If you encounter any difficulties updating via the Internet, your existing firmware might be too far out of date, you can use the following alternatives to catch up: | ||
| * Method 2: [[{}docs: | * Method 2: [[{}docs: | ||
| * Method 3: [[{}docs: | * Method 3: [[{}docs: | ||
