| Both sides previous revision Previous revision | |||
docs:interface:connect-generic [2024/08/05 15:15] 127.0.0.1 external edit |
docs:interface:connect-generic [2024/10/17 13:51] (current) admin |
| Line 1: | Line 1: | ||
| ===== 5.2 Connecting OpenBuilds Interface to other Grbl controllers ===== | ===== 5.2 Connecting OpenBuilds Interface to other Grbl controllers ===== | ||
| - | The OpenBuilds Interface | + | The OpenBuilds Interface can be wired to almost any Grbl 1.1 based CNC controller if it has a UART to connect to. |
| You will likely need to make up / modify your own cabling, the included cable is designed to be a direct fit for OpenBuilds BlackBox. | You will likely need to make up / modify your own cabling, the included cable is designed to be a direct fit for OpenBuilds BlackBox. | ||
| ==== Pinout ==== | ==== Pinout ==== | ||
| - | ^ Pin on Interface' | + | ^Pin on Interface' |
| - | | 5V | + | |5V |5V |5V output from your controller, to provide power for the Interface (500mA required)| |
| - | | GND | GND | Ground connection for serial and power | | + | |GND |GND |Ground connection for serial and power| |
| - | | RX | + | |RX |TX |Connects to Transmit pin on your controller' |
| - | | TX | + | |TX |RX |Connects to Receive pin on your controller' |
| ==== xPro Wiring ==== | ==== xPro Wiring ==== | ||
| - | Refer to our forums at https:// | + | Refer to our forums at https:// |
