| Next revision | Previous revision | ||
docs:blackbox-x32:wifi_setup [2023/04/26 15:38] admin created |
docs:blackbox-x32:wifi_setup [2024/08/05 15:15] (current) |
| Line 6: | Line 6: | ||
| ===Wifi Setup using OpenBuilds CONTROL=== | ===Wifi Setup using OpenBuilds CONTROL=== | ||
| - | * Open OpenBuildsCONTROL | + | * Open [[docs: |
| * Connect to the BlackBox X32 using the Serial port | * Connect to the BlackBox X32 using the Serial port | ||
| * Click the Grbl Settings tab | * Click the Grbl Settings tab | ||
