docs:blackbox-x32:install-drivers [2024/02/20 19:57] admin |
docs:blackbox-x32:install-drivers [2024/08/05 15:15] (current) |
| Line 12: | Line 12: | ||
| - | === USB DRIVER INSTALL | + | === WINDOWS |
| - | Download and Install the SiLabs USB Driver to enable your BlackBox X32 to run on your computer | + | |
| - | {{fa> | ||
| - | {{fa>apple|Apple}} Download | + | {{fa>windows|Windows}} Download |
| + | Once downloaded, run the Installer and Install the Drivers. This single installer covers all our devices | ||
| - | ---- | + | > Also be sure to turn off USB suspend [[docs: |
| - | === USB DRIVER INSTALL | + | {{:docs: |
| + | After completing the install, please Reboot | ||
| - | Download and Install the FTDI USB Driver to enable your BlackBox X32 to run on your computer | ||
| - | {{fa> | ||
| - | === TURN SUSPEND MODE OFF === | + | === APPLE USB DRIVER INSTALL |
| - | > Also be sure to turn off USB suspend [[docs: | + | |
| + | {{fa>apple|Apple}} MacOS should already include Drivers as of MacOS 10.15 | ||
