docs:blackbox-x32:firmware_changelog [2023/05/08 18:44] admin |
docs:blackbox-x32:firmware_changelog [2024/08/05 15:15] (current) |
| Line 5: | Line 5: | ||
| As grblHAL is a modern, fast developing firmware, we will be releasing firmware updates for the BlackBox X32 somewhat regularly. This page is a running log of changes made to the firmware images included in CONTROL. | As grblHAL is a modern, fast developing firmware, we will be releasing firmware updates for the BlackBox X32 somewhat regularly. This page is a running log of changes made to the firmware images included in CONTROL. | ||
| - | ===CONTROL v1.0.368: 8 May 2023=== | + | ===CONTROL v1.0.371: 16 April 2024 === |
| - | - Updated firmware to grblHAL Build 20230501 | + | |
| - | - Added 3-Axes DOOR firmware | + | ===CONTROL v1.0.368: |
| + | * Updated firmware to grblHAL Build 20230501 | ||
| + | * Added 3-Axes DOOR firmware | ||
| ===CONTROL v1.0.341: | ===CONTROL v1.0.341: | ||
| - | - Fixed a bug related to Y2 Motors | + | * Fixed a bug related to Y2 Motors |
| ===CONTROL v1.0.339: | ===CONTROL v1.0.339: | ||
| - | - Fixed a bug that stalls probe moves if a G10 command was sent prior to the probing operation: https:// | + | * Fixed a bug that stalls probe moves if a G10 command was sent prior to the probing operation: https:// |
