docs:blackbox-x32:firmware [2022/12/07 18:29] admin |
docs:blackbox-x32:firmware [2024/08/05 15:15] (current) |
| Line 1: | Line 1: | ||
| - | ===== 4.4 BlackBox X32 Firmware Updates ===== | + | ===== 7.1 BlackBox X32 Firmware Updates ===== |
| As the OpenBuilds BlackBox X32 runs on a cutting edge modern firmware called grblHAL https:// | As the OpenBuilds BlackBox X32 runs on a cutting edge modern firmware called grblHAL https:// | ||
| It's quite easy and very safe to do. | It's quite easy and very safe to do. | ||
| + | Checkout section [[docs: | ||
| ===1) Backup your Grbl Settings (Just in case!) === | ===1) Backup your Grbl Settings (Just in case!) === | ||
| Line 11: | Line 13: | ||
| ===2) Make sure your version of CONTROL is up to date (As we include the latest precompiled firmware images inside CONTROL updates) === | ===2) Make sure your version of CONTROL is up to date (As we include the latest precompiled firmware images inside CONTROL updates) === | ||
| - | Download | + | Download |
| ===3) Launch the Firmware Flashing Tool in CONTROL from the Wizards and Tools menu=== | ===3) Launch the Firmware Flashing Tool in CONTROL from the Wizards and Tools menu=== | ||
