docs:blackbox-x32:faq-bootloader [2024/04/29 17:22] admin |
docs:blackbox-x32:faq-bootloader [2024/08/05 15:15] (current) |
| Line 14: | Line 14: | ||
| === Reset into Bootloader Mode === | === Reset into Bootloader Mode === | ||
| - | We will use the two buttons on the front of the BlackBox X32, to put the BlackBox X32into | + | We will use the two buttons on the front of the BlackBox X32, to put it into " |
| - | * Hold down the **MODE** button keep holding it down (This will tell the controller to be in FLASH mode when it resets) | + | * Hold down the **MODE** button |
| - | * Click the **RESET** button | + | * Click the **RESET** button |
| * Let go of the **MODE** button | * Let go of the **MODE** button | ||
