docs:blackbox-x32:faq-bootloader [2024/04/29 17:18] admin |
docs:blackbox-x32:faq-bootloader [2024/08/05 15:15] (current) |
| Line 1: | Line 1: | ||
| ==== Place BlackBox X32 into Bootloader Mode ==== | ==== Place BlackBox X32 into Bootloader Mode ==== | ||
| + | === Introduction === | ||
| - | Make sure to download | + | If CONTROL is unable |
| - | [[https:// | ||
| - | We will use the two buttons on the front of the BlackBox X32, to put the BlackBox X32into " | ||
| - | | + | This is the procedure you should apply: |
| - | * Click the **RESET** button | + | |
| + | === Reset into Bootloader Mode === | ||
| + | We will use the two buttons on the front of the BlackBox X32, to put it into " | ||
| + | * Click the **RESET** button | ||
| * Let go of the **MODE** button | * Let go of the **MODE** button | ||
