docs:blackbox-x32:connect-rc-servo [2025/01/30 18:06] admin |
docs:blackbox-x32:connect-rc-servo [2025/04/01 18:30] (current) admin |
| Line 1: | Line 1: | ||
| ===== 3.3.6 BlackBox X32 RC Servo ===== | ===== 3.3.6 BlackBox X32 RC Servo ===== | ||
| - | ==== Important note on current (amperage): ==== | + | You can connect a RC Microservo directly to BlackBox: |
| - | Please note the BlackBox can only supply around 250mA for powering micro servos etc. \\ | + | === Important note on current (amperage): === |
| + | Please note the BlackBox can only supply around | ||
| If you want to use a more heavy duty servo that may pull more than 250mA it would be recommended to use an external power source for the servo, otherwise you might damage the BlackBox | If you want to use a more heavy duty servo that may pull more than 250mA it would be recommended to use an external power source for the servo, otherwise you might damage the BlackBox | ||
| === Wiring === | === Wiring === | ||
