docs:blackbox-x32:connect-psu
Differences
Link to this comparison view
Both sides previous revision Previous revision
Next revision
Previous revision
docs:blackbox-x32:connect-psu [2024/06/28 10:52]
admin
docs:blackbox-x32:connect-psu [2025/04/01 18:26] (current)
admin
Line 1: Line 1:
 ===== 3.1 Connecting BlackBox X32 to Power Supply Bundle (OpenBuilds PowerCase on a Meanwell LRS350 24v) ===== ===== 3.1 Connecting BlackBox X32 to Power Supply Bundle (OpenBuilds PowerCase on a Meanwell LRS350 24v) =====
-{{:docs:exclamation.png?100|}} | **IMPORTANT WARNING** Please note, we recommend Meanwell Power supplies to ensure the safety and reliability of your BlackBoxGood quality power supplies ensure good, clean power to the controller. Avoid power supplies marketed as "LED power supplies" as they tend to lack filtering/protection circuitry, that can result in fatal power surges that can destroy your BlackBox. Use of other power supplies may affect your warranty.  |+{{fa>shopping-cart}} Order your [[https://openbuildspartstore.com/blackbox-motion-control-system/|OpenBuilds BlackBox X32 Motion Control System]]
----- +{{fa>shopping-cart}} Order your [[https://openbuildspartstore.com/24v-meanwell-power-supply-bundle/|24V Meanwell Power Supply & PowerCase Bundle]]
-{{fa>shopping-cart}}   Order your [[https://openbuildspartstore.com/blackbox-motion-control-system/|OpenBuilds BlackBox X32 Motion Control System]]  +
-{{fa>shopping-cart}}   Order your [[https://openbuildspartstore.com/24v-meanwell-power-supply-bundle/|24V Meanwell Power Supply & PowerCase Bundle]] +
Line 15: Line 11:
 Before connecting your power supply to mains power, it is critical that you check and set the 115v/230v Switch on the right-side of the PSU: Before connecting your power supply to mains power, it is critical that you check and set the 115v/230v Switch on the right-side of the PSU:
-{{:docs:blackbox-x32:meanwell-110v-switch.png?400|}}+{{:docs:blackbox-x32:meanwell-110v-switch.png?400}}
 Look out for the bright yellow sticker on the top, to help you locate the switch: Look out for the bright yellow sticker on the top, to help you locate the switch:
-{{:docs:powercase:meanwell-sticker.png?200|}}+{{:docs:powercase:meanwell-sticker.png?200}}
Line 25: Line 21:
 ==== 3.1.2 Connecting OpenBuilds PowerCase on a Meanwell LRS350 24v to the BlackBox X32 ==== ==== 3.1.2 Connecting OpenBuilds PowerCase on a Meanwell LRS350 24v to the BlackBox X32 ====
-| {{:docs:exclamation.png?100|}} | **IMPORTANT WARNING No 2**:  Please note, double check your Polarity - wiring a BlackBox with reversed polarity will destroy it. Also never work on wiring of any sorts while power is on. Double check all wiring before turning on the power supply in case any mistakes were made. |+|{{:docs:exclamation.png?100}}|**IMPORTANT WARNING**: Please note, double check your Polarity - wiring a BlackBox with reversed polarity will destroy it. Also never work on wiring of any sorts while power is on. Double check all wiring before turning on the power supply in case any mistakes were made.  |
 +|{{:docs:exclamation.png?100}}|**IMPORTANT WARNING**: Please note, we recommend Meanwell Power supplies to ensure the safety and reliability of your BlackBox. Good quality power supplies ensure good, clean power to the controller. Avoid power supplies marketed as "LED power supplies" as they tend to lack filtering/protection circuitry, that can result in fatal power surges that can destroy your BlackBox. Use of other power supplies may affect your warranty.  |
 +{{:docs:blackbox-x32:meanwell-powersupply.png?800}}
-{{:docs:blackbox-x32:meanwell-powersupply.png?800|}}
docs/blackbox-x32/connect-psu.1719571964.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
