docs:blackbox-x32:connect-door-sensor [2023/05/08 18:51] admin |
docs:blackbox-x32:connect-door-sensor [2024/08/05 15:15] (current) |
| Line 1: | Line 1: | ||
| - | ====== 3.6 Connecting BlackBox X32 to a Door Sensor (Machine Enclosures) (Advanced) | + | ====== 3.6 Connecting BlackBox X32 to a Door Sensor (Machine Enclosures) (Advanced) ====== |
| OpenBuilds BlackBox supports the door-ajar detection features available in Grbl. In order to activate this feature, ensure you run a custom compiled version of GrblHAL that has this feature enabled. It is not available in the default Grbl configuration. | OpenBuilds BlackBox supports the door-ajar detection features available in Grbl. In order to activate this feature, ensure you run a custom compiled version of GrblHAL that has this feature enabled. It is not available in the default Grbl configuration. | ||
| Note: This is an advanced feature, specific to machines with an enclosure, and not required for everyday use. | Note: This is an advanced feature, specific to machines with an enclosure, and not required for everyday use. | ||
| + | === Operation === | ||
| + | * Open the door to pause (and optionally park) | ||
| + | * Close the door to take grbl/ | ||
| === Firmware === | === Firmware === | ||
