docs:scribe:mount-acro
Install Scribe on an OpenBuilds ACRO
Using the two included tee nuts and screws install ACRO Pen lifter with the servo flush to the bottom of the ACRO main plate.
Slide the servo up flush to touch the bottom edge of the main plate
TIP: If you have the laser mounting plate installed, please remove it first
NOTE: The tee nut flange should face into the main plate slot, as shown below
No need to over tighten the screws, just snug in place
docs/scribe/mount-acro.txt · Last modified: 2024/12/03 19:32 by admin
