docs:scribe:cam
Configure OpenBuilds CAM to use the Scribe Pen Lifter
Navigate to OpenBuilds CAM and click on the Settings tab, then on the Settings button
Inside the Application Settings window (if not already done before) select the machine you have in section (1); then under the Add-Ons in section (2) tick off the “SCRIBE Pen Lifter”
Click SAVE
docs/scribe/cam.txt · Last modified: 2024/12/06 12:32 by admin
