docs:blox:wifi
3.4 WIFI
Blox has onboard Wireless Networking
  • Wi-Fi Standards: 802.11 b/g/n
  • Frequency Band: 2.4 GHz
  • Security: WPA/WPA2
  • Max Data Rate: Up to 150 Mbps (802.11n)
3.3.3 Configuration
3.3.3.1 grblHAL/CONTROL
Can be used with CONTROL https://software.openbuilds.com/, grblHAL WebUI https://github.com/grblHAL/Plugin_WebUI etc
  • $74=Your Network SSID
  • $75=Your Network PSK (Password)
3.3.3.2 LogiBLOX
You can configure your BLOX to join a Wifi Network
You can check if you are connected, and manage the flow of your program accordingly
Supports mDNS Hostnames
Send / Receive UDP Broadcast packets to manage remote sensors and events
Using the Wifi network, you can syncronise local time on the device using NTP, and with valid Time, you can run Scheduled tasks at certain days/times
With an I2S Audio DAC, you can also use the Wifi network to stream audio files, or even do Text-to-speak using the Google TTS API
docs/blox/wifi.1723144700.txt.gz · Last modified: 2024/08/08 19:18 by admin
