docs:blox:sdcard
3.2 SD Card
Blox has an onboard SD Card socket. You can use this to store data
3.3.2 Configuration
3.3.2.1 grblHAL/CONTROL
3.3.2.2 LogiBLOX
  • Reset Button reboots the device
  • Mode Button is available as a Digital Sensor
  • Holding MODE while pressing Reset enters Bootloader Mode
In LogiBLOX, the SD Card can be used:
To log sensor values to a CSV file
To store Audio files to play using an I2S DAC
Formatting an SD Card on demand (For example whenever the Mode button is pressed in this example)
docs/blox/sdcard.1723139007.txt.gz · Last modified: 2024/08/08 17:43 by admin
