docs:blox:jumper-limitswitchvoltage
2.1.1 Set your Endstop Voltages
5V Endstops (Default)
12-30V Endstops
docs/blox/jumper-limitswitchvoltage.1722880364.txt.gz · Last modified: 2024/08/05 17:52 by admin
