docs:blox:jumper-limitswitchvoltage
2.1.1 Set your Endstop Voltages
Limit1 and Limit2 can each be set to individually as needed:
5V Endstops
12-30V Endstops
docs/blox/jumper-limitswitchvoltage.1722862520.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
