docs:blox:jumper-limitswitchvoltage
2.1.1 Set your Endstop Voltages
5V Endstops: Set the "Limit V+" Jumper to the 5V Setting
24V Endstops: Set the "Limit V+" Jumper to the 24V Setting
docs/blox/jumper-limitswitchvoltage.1722860586.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
