docs:blox:firmware-grblhal
4.3.1 Download and install OpenBuilds CONTROL
https://software.openbuilds.com
Runs on Windows, Mac and Linux
After installation, start OpenBuilds CONTROL.
4.3.2 Flash grblHAL firmware
In CONTROL go to Wizards and Tools > Firmware Flashing Tool
Inside the Firmware Flashing Tool, click on the BLOX tab
Follow the onscreen instructions to place the BLOX into Bootloader Mode
Select the correct Port, Machine Style relevant to the machine you are building (Standard and CoreXY kinematic supported) and click FLASH to flash the firmware
The Log/Serial Terminal will display the progress as the tool writes the firmware to the BLOX.
Once it completes press the RESET button on the BLOX to let it boot up with grblHAL firmware
Once booted up, the Port ID will change and it will identify itself as a grblHAL based controller in the list. You can now CONNECT to it.
You are now connected
4.3.4 BLOX grblHAL Settings
Stepper Driver Current:
BLOX has software controller stepper driver current. Set the current in $140/141 = X and Y axis Stepper Driver Current respectively
docs/blox/firmware-grblhal.1723727545.txt.gz · Last modified: 2024/08/15 13:12 by admin
