docs:blox:firmware-grblhal
4.2.1 Requirements
Download Arduino IDE 2:
Install the IDE:
Open the Arduino IDE:
Add the ESP32 Board URL:
Install the ESP32 Core:
Open the Library Manager:
Search for the BLOX Library:
Select the ESP32-S3 Board:
Connect Your BLOX Device:
Also set:
  • USB CDC On Boot = Enabled
  • Flash Size = 8MB (64Mb)
Upload a Sketch:
You can now write or upload a sketch to your BLOX device. Use the examples provided in the BLOX library to get started quickly. Including the OpenBuildsBLOX.h library will help you initialise all the onboard hardware with ease
docs/blox/firmware-grblhal.1723726058.txt.gz · Last modified: 2024/08/15 12:47 by admin
