docs:blox:firmware-arduino
4.2 Using BLOX with the Arduino IDE
4.2.1 Requirements
Download Arduino IDE 2:
Install the IDE:
Open the Arduino IDE:
Add the ESP32 Board URL:
Install the ESP32 Core:
Open the Library Manager:
Search for the BLOX Library:
Select the ESP32-S3 Board:
Connect Your BLOX Device:
Also set:
  • USB CDC On Boot = Enabled
  • Flash Size = 8MB (64Mb)
Upload a Sketch:
You can now write or upload a sketch to your BLOX device. Use the examples provided in the BLOX library to get started quickly. Including the OpenBuildsBLOX.h library will help you initialise all the onboard hardware with ease
4.2.6 Pinmap for custom firmware
If you are not planning on using our library to control the onboard devices as part of your code, you can use the Pin map below to get you started with your own code
// WS2812 LEDs
#define LED_PIN         48
// RC Servo
#define PIN_SERVO       47
// Stepper 1
#define DIR_1           8
#define STEP_1          9
#define ENABLE_1        10
#define FAULT_1         11
// Remember to setup MCP4725 I2C DAC (Addr 0x60) to set Stepper Driver Current
// Stepper 2
#define DIR_2           12
#define STEP_2          13
#define ENABLE_2        14
#define FAULT_2         15
// Remember to setup MCP4725 I2C DAC (Addr 0x61) to set Stepper Driver Current
// Limits Inputs
#define LIMIT_SENSOR_1  39
#define LIMIT_SENSOR_2  40
// Mosfets
#define PIN_MOSFET1     41
#define PIN_MOSFET2     42
// Beeper
#define BUZZER_PIN      7
// I2C
#define I2C_SDA         3
#define I2C_SCL         4
// SPI
#define SPI_MOSI        35
#define SPI_MISO        37
#define SPI_SCK         36
// SD Card
#define SD_CS           5
docs/blox/firmware-arduino.1723728620.txt.gz · Last modified: 2024/08/15 13:30 by admin
