docs:blox:firmware-arduino
4.2 Using BLOX with the Arduino IDE
4.2.1 Requirements
Download Arduino IDE 2:
Install the IDE:
Open the Arduino IDE:
Add the ESP32 Board URL:
Install the ESP32 Core:
Open the Library Manager:
Search for the BLOX Library:
Select the ESP32-S3 Board:
Connect Your BLOX Device:
Also set:
  • USB CDC On Boot = Enabled
  • Flash Size = 8MB (64Mb)
Upload a Sketch:
You can now write or upload a sketch to your BLOX device. Use the examples provided in the BLOX library to get started quickly. Including the OpenBuildsBLOX.h library will help you initialise all the onboard hardware with ease
4.2.6 Pinmap for custom firmware
If you are not planning on using our library to control the onboard devices as part of your code, you can use the Pin map below to get you started with your own code
// WS2812 LEDs
#define LED_PIN    48
// RC Servo
#define PIN_SERVO          47
// Stepper 1
const int DIR_1 = 8;  // Stepper1 DIR
const int STEP_1 = 9; // Stepper1 STEP
const int ENABLE_1 = 10; // Stepper1 ENABLE
const int FAULT_1 = 11; // Stepper1 Fault
// Remember to setup MCP4725 I2C DAC (Addr 0x60) to set Stepper Driver Current
// Stepper 2
const int DIR_2 = 12;  // Stepper2 DIR
const int STEP_2 = 13; // Stepper2 STEP
const int ENABLE_2 = 14; // Stepper2 Enable
const int FAULT_2 = 15; // Stepper2 Fault
// Remember to setup MCP4725 I2C DAC (Addr 0x61) to set Stepper Driver Current
// Limits Inputs
#define LIMIT_SENSOR_1 39 // Pin for the first limit sensor
#define LIMIT_SENSOR_2 40 // Pin for the second limit sensor
// Mosfets
#define PIN_MOSFET1 41
#define PIN_MOSFET2 42
// Beeper
#define BUZZER_PIN 7
// I2C
#define I2C_SDA 3
#define I2C_SCL 4
// SPI
#define SPI_MOSI 35
#define SPI_MISO 37
#define SPI_SCK 36
// SD Card
#define SD_CS 5
docs/blox/firmware-arduino.1723728475.txt.gz · Last modified: 2024/08/15 13:27 by admin
