docs:blox:firmware-arduino
4.2 Arduino IDE Setup
4.2.1 Requirements
Download Arduino IDE 2:
Install the IDE:
Open the Arduino IDE:
Add the ESP32 Board URL:
Install the ESP32 Core:
Open the Library Manager:
Search for the BLOX Library:
Select the ESP32-S3 Board:
Connect Your BLOX Device:
Also set:
  • USB CDC On Boot = Enabled
  • Flash Size = 8MB (64Mb)
Upload a Sketch:
You can now write or upload a sketch to your BLOX device. Use the examples provided in the BLOX library to get started quickly.
docs/blox/firmware-arduino.1723668650.txt.gz · Last modified: 2024/08/14 20:50 by admin
