docs:blox:firmware-arduino
4.2 Arduino IDE Setup
4.2.1 Requirements
Download Arduino IDE 2:
Install the IDE:
Open the Arduino IDE:
Add the ESP32 Board URL:
Install the ESP32 Core:
Open the Library Manager:
Search for the BLOX Library:
Alternatively, you can install the library manually by downloading it from the [OpenBuilds BLOX GitHub repository](https://github.com/OpenBuilds/OpenBuildsBLOX/).
Select the ESP32 Board:
Connect Your BLOX Device:
Upload a Sketch:
You can now write or upload a sketch to your BLOX device. Use the examples provided in the BLOX library to get started quickly.
docs/blox/firmware-arduino.1723668130.txt.gz · Last modified: 2024/08/14 20:42 by admin
