docs:blox:firmware-arduino
4.2 Arduino IDE Setup
4.2.1 Requirements
1. Download Arduino IDE 2:
  1. Visit the [Arduino IDE download page](https://www.arduino.cc/en/software) and select the appropriate version for your operating system.
2. Install the IDE:
  1. Follow the installation instructions provided on the website. Once the installation is complete, launch the Arduino IDE.
1. Open the Arduino IDE:
  1. Launch the Arduino IDE and navigate to `File > Preferences`.
2. Add the ESP32 Board URL:
  1. In the “Additional Boards Manager URLs” field, enter the following URL:
   ''https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json''
 - Click "OK" to save the preferences.
3. Install the ESP32 Core:
  1. Go to `Tools > Board > Boards Manager`.
  2. In the search bar, type “ESP32” and install the latest version of the ESP32 by Espressif Systems.
1. Open the Library Manager:
  1. Go to `Sketch > Include Library > Manage Libraries`.
2. Search for the BLOX Library:
  1. In the Library Manager, search for “OpenBuilds BLOX”.
  2. Click “Install” to add the library to your Arduino IDE.
 Alternatively, you can install the library manually by downloading it from the [OpenBuilds BLOX GitHub repository](https://github.com/OpenBuilds/OpenBuildsBLOX/).
1. Select the ESP32 Board:
  1. Go to `Tools > Board` and select the appropriate ESP32 board for your BLOX device.
2. Connect Your BLOX Device:
  1. Connect the BLOX device to your computer via USB. Ensure the correct port is selected in `Tools > Port`.
3. Upload a Sketch:
  1. You can now write or upload a sketch to your BLOX device. Use the examples provided in the BLOX library to get started quickly.
docs/blox/firmware-arduino.1723667869.txt.gz · Last modified: 2024/08/14 20:37 by admin
