docs:blox:fcc
OpenBuilds® BLOX
Layout Information
Product Manual
FCC Information
However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures:
The device has been evaluated to meet general RF exposure requirement. The device can be u sed in portable exposure condition without restriction
docs/blox/fcc.1722436987.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
