docs:blox:fcc
OpenBuilds® BLOX
Layout Information
Product Manual
FCC Warning
– Reorient or relocate the receiving antenna.
– Increase the separation between the equipment and receiver.
– Connect the equipment into an outlet on a circuit different from that to which the receiver is connected.
– Consult the dealer or an experienced radio/TV technician for help.
The device has been evaluated to meet general RF exposure requirement. The device can be u sed in portable exposure condition without restriction
docs/blox/fcc.1722436535.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
