docs:blox:examples-xystage
7.2 XY Stage Examples
BLOX can be used with 2-axes machines
7.2.1 Initialization for XY Stages
Before you can use a 2-axis system, you need to set it up so the controller knows how to control it correctly. Make use of the Initialization Blocks to configure them for use with the BLOX:
Linear ActuatorsDetails Initialization Blocks
C-Beam XLarge X/Y Table
Lead Screw Driven
TR8*8-2P (4 starts) Leadscrew
NEMA 23 Motor
400 Steps per millimeter
Acceleration: +-150 mm/sec²
OpenBuilds ACRO System
Belt Driven
GT2-2M Timing Belts
14T Pulley
NEMA 17 Motor
114.29 Steps per millimeter
Acceleration: +-350 mm/sec²
docs/blox/examples-xystage.1724074782.txt.gz · Last modified: 2024/08/19 13:39 by admin
