docs:blox:examples-servo
6.4.1 BLOX with Servos
BLOX can be used with Servos, Speed controllers, and other accesories from the Radio Control world that accepts a standard Servo signal. You can set the angle explicitly or, if you make use of the “Apply Analog Sensor Value” block and place the “Move Servo” block inside it, you can map the sensor value to the servo's position.
6.4.2.1 Moving a Servo / Sending a Servo Signal
Move Servo Move relative to sensor value
docs/blox/examples-servo.1724262043.txt.gz · Last modified: 2024/08/21 17:40 by admin
