docs:blox:examples-logic
6.2 BLOX: Events and Logic
6.2.1 Everything Happens Sequentially
6.2.2 Logic Flow Control
  • In BLOX, you can use logic blocks like “if” to control what your robot does based on different conditions. This way, you can make your device smart enough to handle different situations automatically.
6.2.3 Sequential Instructions
- Set both LEDs to RED
- Wait for 1 second
- Set both LEDs to GREEN
- wait for 1 second
- Set both LEDs to BLUE
- wait for 1 second
It's really that easy! You can substitute the LEDs for any other output and already build out a couple interesting projects
6.2.4 Control flow of Instructions using a Logic block
Let's expand upon our basic example
Lets add a little logic to the program. Suppose we only want the LED pattern to run, if a certain condition is being met. For the sake of simplicity, lets use the onboard MODE button as an input. We only want the program to run if the MODE button is pressed, otherwise, just turn the LEDs Purple.
IF the button is pressed:
- Wait for 1 second
- wait for 1 second
- wait for 1 second
ELSE
- set the LEDs to Purple
You can apply this exact concept to a lot of other examples
  • Waiting for a motion sensor before using the Beeper to make on an alarm sound
  • Waiting for a button press before raising a TV lift actuator
  • Read the status of a garage door sensor and display the status on an LCD
  • Use it as a thermostat, if the temperature drop below a certain value, turn on a heating device
docs/blox/examples-logic.1724100298.txt.gz · Last modified: 2024/08/19 20:44 by admin
