docs:blox:examples-logic
6.1 BLOX: Logic and Events
Everything Happens Sequentially:
Logic Flow Control:
Sequential Instructions
- Set both LEDs to RED
- Wait for 1 second
- Set both LEDs to GREEN
- wait for 1 second
- Set both LEDs to BLUE
- wait for 1 second
It's really that easy!
Control flow of Instructions using an IF block
Let's expand upon our basic example
Lets add a little logic to the program. Suppose we only want the LED pattern to run, if a certain condition is being met. For the sake of simplicity, lets use the onboard MODE button as an input. We only want the program to run if the MODE button is pressed, otherwise, just turn the LEDs Purple.
IF the button is pressed:
- Wait for 1 second
- wait for 1 second
- wait for 1 second
ELSE
- set the LEDs to Purple
Now you have a basic grasp of the workflow, you can start to develop your program in more interesting ways
docs/blox/examples-logic.1724096463.txt.gz · Last modified: 2024/08/19 19:41 by admin
