docs:blox:examples-logic
6.1 BLOX: Logic and Events
Everything Happens Sequentially:
Logic Flow Control:
Sequential Instructions
- Set both LEDs to RED
- Wait for 1 second
- Set both LEDs to GREEN
- wait for 1 second
- Set both LEDs to BLUE
- wait for 1 second
It's really that easy!
docs/blox/examples-logic.1724096173.txt.gz · Last modified: 2024/08/19 19:36 by admin
