docs:blox:examples-logic
6.1 BLOX: Logic and Events
Everything Happens Sequentially:
Logic Flow Control:
To demonstrate this, lets start with a very basic example.
Your BLOX has two onboard RGB LEDs. Let's setup a simple program to control these LEDs.
docs/blox/examples-logic.1724095926.txt.gz · Last modified: 2024/08/19 19:32 by admin
