docs:blox:examples-logic
6.1 BLOX: Logic and Events
Everything Happens Sequentially:
Logic Flow Control:
To demonstrate this, lets start with a very basic example.
Your BLOX has two onboard RGB LEDs. Let's setup a simple program to control these LEDs.
- Wait for 1 second
  1. Set both LEDs to GREEN
  2. wait for 1 second
  3. Set both LEDs to BLUE
  4. wait for 1 second
  5. Then repeat (the pattern will run over and over)
docs/blox/examples-logic.1724095888.txt.gz · Last modified: 2024/08/19 19:31 by admin
