docs:blox:examples-logic
6.1 BLOX: Logic and Events
Everything Happens Sequentially:
Logic Flow Control:
To demonstrate this, lets start with a very basic example.
Your BLOX has two onboard RGB LEDs. Let's setup a simple program to control these LEDs.
Once it starts to run the firmware we want to:
  1. Set both LEDs to RED
  2. Wait for 1 second
  3. Set both LEDs to GREEN
  4. wait for 1 second
  5. Set both LEDs to BLUE
  6. wait for 1 second
  7. Then repeat (the pattern will run over and over)
If we build this out in BLOX it would look like this:
docs/blox/examples-logic.1724095674.txt.gz · Last modified: 2024/08/19 19:27 by admin
