docs:blox:examples-leds
6.4.5 Using onboard and addressable LEDs with BLOX
BLOX can be used to control addressable LEDs. It has two already onboard ready to use
6.4.5.1 Onboard LEDs
You can set the colors of the onboard LEDs using the “Set BLOX LED Colors” block. Ideal for use at different stages of your program to show status or progress
docs/blox/examples-leds.txt · Last modified: 2024/08/28 17:53 by admin
