docs:blox:examples-audio-i2s
6.4.7 Audio: I2S
BLOX can be used to to play audio in more complicated projects via an external I2S Audio decoder module
Use a soldering iron to close the relevant solder jumpers on your module:
Name Description Setting
SCK Jumper to connect SCK to GND CLOSED
H Name Description LOW HIGH Jumper must be set to
H1L FLT Filter Select Normal Latency Low Latency L
H2L DEMP De-emphasus control OFF ON L
H3L XMST Soft Mute Control Muted Unmuted H
H4L FMT Audio Format Selection I2S Left Justified L
Note: You can use any of the available GPIO pins to connect the module. Just be sure to initialize the firmware with the correct assignments.
docs/blox/examples-audio-i2s.1724681417.txt.gz · Last modified: 2024/08/26 14:10 by admin
