docs:blox:examples-audio-i2s
6.4.7 Audio: I2S
BLOX can be used to to play audio in more complicated projects via an external I2S Audio decoder module
Name Description Setting
SCK Jumper to connect SCK to GND CLOSED
H Name Description LOW HIGH Jumper must be set to
H1L FLT Filter Select Normal Latency Low Latency L
H2L DEMP De-emphasus control OFF ON L
H3L XMST Soft Mute Control Muted Unmuted H
H4L FMT Audio Format Selection I2S Left Justified L
docs/blox/examples-audio-i2s.1724681131.txt.gz · Last modified: 2024/08/26 14:05 by admin
