docs:blox:examples-audio-i2s
6.4.7 Audio: I2S
BLOX can be used to to play audio in more complicated projects via an external I2S Audio decoder module
H Name Description LOW HIGH Jumper must be set to
H1L FLT Filter Select Normal Latency (SELECT) Low Latency L
H2L DEMP De-emphasus control OFF (SELECT) ON L
H3L XMST Soft Mute Control Muted Unmuted (SELECT) H
H4L FMT Audio Format Selection I2S (SELECT) Left Justified L
docs/blox/examples-audio-i2s.1724680746.txt.gz · Last modified: 2024/08/26 13:59 by admin
