docs:blox:examples-audio
6.4.6 Audio
BLOX can be used to log sensor data, either for immediate review, or logged to SD Card for long term analysis
6.4.6.1 Notifications via onboard beeper, using RTTTL melodies
6.4.6.2 Notifications via onboard beeper, using built in Notifications
6.4.6.3 HD Audio output via I2S DAC Module
6.4.6.3.1 Wiring PCM5102a Module
6.4.6.3.2 Configure PCM5102a Module
6.4.6.4 I2S Audio: Play audio files from SD Card
6.4.6.5 I2S Audio: Play audio via stream URL
6.4.6.6 I2S Audio: Use text to speech
docs/blox/examples-audio.1724678855.txt.gz · Last modified: 2024/08/26 13:27 by admin
