docs:blox:examples-audio
6.4.6 Audio: Onboard Beeper
BLOX can be used to to play notifications via the Onboard beeper, or more complicated projects can be done via external I2S Audio decoder modules
6.4.6.1 Notifications via onboard beeper
BLOX provides a couple default noises you can use to signify events with an audible notification using the “Play Notification” block.
6.4.6.2 Notifications via onboard beeper, using RTTTL melodies
BLOX can also play custom melodies provided in RTTTL format
RTTTL stands for Ringing Tone Text Transfer Language, a simple text-based format used to encode monophonic ringtones for mobile phones, particularly for older models before the advent of polyphonic and MP3 ringtones. It was in use for a very long time, so there are thousands of RTTTL melodies available online:
Find some examples on
Simply paste the RTTTL string into the “Play RTTTL Melody” block
docs/blox/examples-audio.txt · Last modified: 2024/08/26 14:19 by admin
