docs:blox:examples-actuator
6.4.1 BLOX with Linear Actuators
BLOX can be used with all the OpenBuilds Linear Actuators available at OpenBuilds Partstore: Linear Actuators as well as 2-axes motion platforms like the ACRO
If you want to move something, lift something or slide something this is the way to go!
6.4.1.1 Initialization for Actuators
Before you can use an actuator, you need to set it up so the controller knows how to control it correctly. Make use of the Initialization Blocks to configure them for use with the BLOX:
Drag the “Set Stepper Motor max current to” and “Set up Linear Axis” blocks into the Initialize input of your BLOX Block
Use the table below to find some default values to use for Current settings, Steps-per-mm and Acceleration
Linear ActuatorsDetails Initialization Blocks
V-Slot® Mini V Actuator
Belt Driven
GT2-2M Timing Belts
30T Pulley
NEMA 17 Motor
Steps per millimeter: 53.33
Recommended Acceleration: +-900mm/sec²
Recommended Feedrate: 0-250mm/sec
Recommended Stepper Current: 1.0A
V-Slot® NEMA 17 Belt Actuator
Belt Driven
GT2-2M Timing Belts
30T Pulley
NEMA 17 Motor
Belt and Pinion NEMA 17 Actuator
Belt Driven
GT2-2M Timing Belts
30T Pulley
NEMA 17 Motor
Recommended Feedrate: 0-500mm/sec
Belt and Pinion NEMA 23 Actuator
Belt Driven
3GT-2M Timing Belts
20T Pulley
NEMA23 Motor
Recommended Stepper Current: 2.2A
V-Slot® NEMA 23 Belt Actuator
Belt Driven
3GT-2M Timing Belts
20T Pulley
NEMA23 Motor
Recommended Stepper Current: 1.5A
V-Slot® NEMA 17 Lead Screw Actuator
Lead Screw Driven
TR8*8-2P (4 starts) Leadscrew
NEMA 17 Motor
Steps per millimeter: 400
Recommended Acceleration: +-300mm/sec²
Recommended Feedrate: 0-100mm/sec
Recommended Stepper Current: 1.2A
V-Slot® NEMA 23 Lead Screw Actuator
Lead Screw Driven
NEMA 23 Motor
Recommended Acceleration: +-500mm/sec²
Recommended Feedrate: 0-80mm/sec
C-Beam Actuator
Lead Screw Driven
NEMA 23 Motor
Recommended Feedrate: 0-800mm/sec
Recommended Stepper Current: 1.7A
C-Beam XLarge Actuator
Lead Screw Driven
NEMA 23 Motor
C-Beam Double Wide Actuator
Lead Screw Driven
NEMA 23 Motor
C-Beam Tension XLarge Actuator
Lead Screw Driven
NEMA 23 Motor
Recommended Feedrate: 0-80mm/second
6.4.1.2 Initialization for XY Stages
Before you can also be used as a 2-axis system. You need to set it up so the controller knows how to control it correctly. Make use of the Initialization Blocks to configure them for use with the BLOX:
TIP: For more advanced 2-axes Motion control, check out grblHAL as an alternative
Drag the “Set Stepper Motor max current to” and “Set up Linear Axis” blocks into the Initialize input of your BLOX Block, set it up for both axes
2 Axis ActuatorsDetailsInitialization Blocks
C-Beam XLarge X/Y Table Lead Screw Driven TR8*8-2P (4 starts) Leadscrew NEMA 23 Motor
OpenBuilds ACRO System
Belt Driven
GT2-2M Timing Belts
14T Pulley
NEMA 17 Motor
Steps per millimeter: 114.29
Recommended Acceleration: +-1200mm/sec²
docs/blox/examples-actuator.1724260239.txt.gz · Last modified: 2024/08/21 17:10 by admin
