docs:blox:connect-ws2812
2.2 Connecting BLOX to WS2812 Addressable RGB LEDs
  • Max Current: 2A
  • LED Type: WS2812B
2.2.1 Wiring
BLOX Terminal Device
GND GND
5V 5V IN
LDO DIN (LED Data In)
2.2.2 Configuration
2.2.2.1 grblHAL / CONTROL
Make sure to set $536=0-255 (WS2812B LED strip length) in grblHAL settings (CONTROL > Grbl Settings Tab > Scroll down to$536 WS2812B LED strip length > Set the value to 2+'number of LEDs on the attached strip/matrix/circle' and Save.
That is because BLOX has two onboard LEDs. So if you add a 24-LED strip, you should set $536 = 2+24 thus $536=26
2.2.2.2 BLOX
You can set the Onboard LED colors manually
You can also use the LEDs in the Apply Analog Sensor Value block for dynamic changes to Color shift, Brightness or Saturation:
docs/blox/connect-ws2812.1723228727.txt.gz · Last modified: 2024/08/09 18:38 by admin
