docs:blox:connect-ws2812
2.2 Connecting BLOX to WS2812 Addressable RGB LEDs
  • Max Current: 2A
  • LED Type: WS2812B
2.2.1 Wiring
BLOX Terminal Device
GND GND
5V 5V IN
LDO DIN (LED Data In)
2.2.2 Configuration
2.2.2.1 grblHAL / CONTROL
Make sure to set $536=0-255 (WS2812B LED strip length) in grblHAL settings (CONTROL > Grbl Settings Tab > Scroll down to$536 WS2812B LED strip length > Set the value to 2+'number of LEDs on the attached strip/matrix/circle' and Save.
That is because BLOX has two onboard LEDs. So if you add a 24-LED strip, you should set $536 = 2+24 thus $536=26
2.2.2.2 LogiBLOX
You can set the Onboard LED colors from LogiBLOX
You can also use the LEDs in the Apply Analog Sensor Value block:
docs/blox/connect-ws2812.1723140415.txt.gz · Last modified: 2024/08/08 18:06 by admin
